Collab 2020: Modeling Heavy Equipment (Backhoe)
Collaborations
Accomplishing a BIG project TOGETHER
Starting in March 2020, I began a large stream project to model a comprehensive, highly-detailed Caterpillar 434E backhoe. Please watch the first stream (first 3 minutes of abridged version at least) for an overview.
It's a straight-forward project of building a complex model over an extended period of time. The spin on the project is that I want your help to accomplish it! If I build some parts and you build some parts, we will finish this thing much quicker. Plus the contribution format will include reviews, the potential of having your piece(s) assimilated into the final model. Not to mention large quantities of XP are at stake 🤑
NOTE: This is an involved project reserved for Citizen members.
Collaboration Details
The general idea is that I kickoff stages of the project via live stream, which is typically once per month. For the time in between streams, you choose a piece of the backhoe and apply what you learned from the stream to that piece. For example, the first stream covered initial block out. So between stream 1 and stream 2, your job is to pick a piece and block it out.
This is the repeating protocol for each Assignment Period (between-streams):
  1. Signing up for pieces of the model. I will be maintaining a Google Sheet to organize piece selection and grading. Following this URL will give you the ability to comment. The sheet is sectioned vertically and color-coordinated with a backhoe image. To sign up for a piece, right click on an empty cell below your desired piece section and click "Comment" (CTRL + ALT + M). Comment your name or username and I will fill it in officially as confirmation.
    Remember that it is OK for multiple people to model the same piece. But lets try to have at least one person assigned to each piece before doubling up.
    2. Project file structure. We're going to use Google Drive as a means to sync a single working directory among all contributors. See this thread about details and how to get set up.
    3. Submitting your piece for review. Exactly one week before the next stream is scheduled to be broadcast, your piece is due. In the "Attempt" cell of the spreadsheet, paste a download link to your .blend file via Dropbox, Google Drive, or equivalent hosting service. This will earn you at least 10 XP each week.
    4. Review. On stream I will review each submitted piece and decide which will be assimilated into the master model (in the case of multiple submissions of the same piece). The purpose of the review is to generate feedback for you work and advice for improvement.
    5. Assimilation. If your piece makes the cut and is assimilated into the master model, your name / username will be added to the object in Blender. You will go down in history as a definitive contributor to this epic backhoe model!
    Once the model is completely done, I plan to render a short demo reel showing off the model and crediting all contributors. It should be a rewarding conclusion to all the work we will do!
Assignment Prompts
I will reply to this thread after each stream with a [big] assignment post denoted by a  📣 emoji in the title. There I will clarify instructions about each Assignment Period.
Online Resources
Reference Images
Livestreams
This is THE thread
We will centralize our collaborative communication between the streams and this thread. Ask any and all questions pertaining to the Backhoe project here.
  • Kent Trammell replied
    dostovel Good question. You can "submit" a .blend file any time by supplying a share like (as you have, which I was able to download fine btw). I'm only going to consider these submissions final after the due date (which is a week before the next stream, April 7th specifically). This means anyone can update their .blend file after submitting via link until April 7th.
    I will post your link to the spreadsheet. Your "battery boxes" look great!
  • adrian replied
    I noticed  the wheel arches are not on the list. So I thought I would have a go. I added a comment and a link.
    Woah, looks like you're finished with those wheel arches! Who needs blockouts anyway 😁
    They look really nice, Adrian. Good work 👍
  • shanr replied
    can muitple people do the same thing.
    if so i can help with the wheels or the bucket :)
  • adrian replied
    Yes multiple people can do the same thing.
    Refer to Collaboration Details at top of feed.👌👆
    This is what I've modeled so far for blockout level 2 of the wheels:
    And a closer look:
  • shanr replied
    @adrain2301 I ment more than two
    Kent I add a comment
  • Greg McKim(doulos4iesou) replied
    [Q] Do you want us to upload the entire scene like we downloaded with the collection for our part, or just the collection?
  • shanr replied
    Kent  can I change job or choose a different part of the blockout
    Here an augmented version of my wheels blockout level 2 with tyre treads:
    PS: I accidentally closed all but one tab (active tool seetings and workspace) in my properties editor as you can see it in the screenshots above the reference images sheet in the bottom right corner. I've fixed it by leaving "Load UI" in the properties region of the blender file browser unchecked. But I stil don't know how I've run into this situation.
  • spikeyxxx replied
    Also blocked out the treads and as the drawing has 23 treads and the pictures 22, I thought it might be fun to give the possibility to change the number of treads. You' ll have to do the front and back wheels separately, but it's working....
    Clever technique! Didn't know that there is now a "weld modifier" in Blender 2.83. I'm just using the good old 2.82 Alpha ;) .
  • spikeyxxx replied
    Actually, I don't think I actually need the Weld Modifier. It's just to make sure, because of rounding errors.
    Here's my last version for the wheels blockout level 2:
    It took me a lot more time than originally thought. I've done the modeling of the inner part of the wheel hub manually by eyeballing. Maybe  it would be more precise using a plane orientated in the same way as the object in the reference image of the planetary gear  and then tracing the outline on the surface while in perspective view. I'm still looking for reference images showing the connection between the wheel hub and the axle. Are the front axle and the back axle identical?
  • spikeyxxx replied
    I just used the pictures that were in the file. I know that all wheels are able to rotate from the description and by the looks of it the front and back are the same, just mirrored....
    In cases like this, you just have to think about how this would be able to work, look at a lot of reference pictures and don't trust those drawings too much!
    Those rim pictures you got are great!
    Your profile of the treads however looks like it is put on top of the tire and the tire is made out of one piece of rubber...
    Yes, I was wondering how this vehicle is driven, but for the heavy work it has to fullfill, I supposed that it uses a four-wheel-drive. My tyre treads have to be reshaped since their outlines are just a very rough approximation. I made them by extruding an edge with snapping "individual elements" on the tyre surface and adding a solidify modifier. The "rubber" look comes from the subsurf modifier. I need to sharpen the tread outlines more after the blocking stage.
    But one more reason to update to Blender 2.83 .
  • spikeyxxx replied
    I don't know if you can access my file, but this is what my tire looks like without Modifiers:
    Quite simple and easy to modify, I think.
    This is the first time I've used the google spreadsheet, so I don't know if I got my dropbox link in it or not. Here's the link in case I screwed something up:
    https://www.dropbox.com/s/e5hoau9endftzop/Engine_block.blend?dl=0
    Yes, I can access your file and have also done it with your first wheel version where I especially admired your already complex blocking of the axles. Your approach of dividing the tyre into repeating segments is a clever idea. I also wanted to find a solution that offers the possibility to manipulate the tread pattern easily. The main focus for the treads now is to match the correct shape better. Later, I'll tackle the transition between the treads and the rest of tyre with a concave beveling so that the treads look like organically "growing" out of the tyre instead of just lying on its surface. There's also a clearly visible bigger bevel towards the tyre sides. By the way: I've already seen 3 different tyre versions by Michelin, Goodyear and Musclerok. I'm  not sure whether Caterpillar offers all 3 of them to the clients or delivers the backhoe just with one standard type.
