BC1-1908 Homework - Katerina Novakova
Collaborations
My homework thread.
  • smurfmier1985 replied
    Kate!! 😃 good to see you back, how are you?
  • Katerina Novakova(shiennar) replied
    Wow, my third BC1 class already :-) I wasn't sure I was going to make this one because I've been very busy lately, but I'll do my best. Each class has been different so far - in this one I want to focus on effectivity: get done as much as possible in the few hours I have. I'll also try to post some in-progress images (I haven't been very good at this, time to improve :-) ) Oh, and I really want to do the class reels again. I hope I'll be able to squeeze them in, I really enjoy making them.
  • spikeyxxx replied
    shiennar Glad you're joining us! I'm really looking forward to see what you make this time!
    ssmurfmier1985 I'm good, Miranda, glad to see you too. :-) I've also had a lot of work lately, so I had to stop doing the weekly projects (but I'm working on something special at the moment - I hope I'll be able to share more details in a couple weeks' time).
    I saw that you already created your own homework thread, I'm looking forward to seeing your completed chest (I'm curious what kind of spin you'll put on it.)
    WIP 1: Barrel stave
    I have a simple scene in mind that I want to create with the barrel (or do I hear barrels?). I want to make them stylized, but with realistic measurements, so I set out to hunt for barrel dimensions. I found those quickly enough. In gallons. And liters. And special wood-working magic units that have been passed from father to son for generations. In centimeters? Not so much.
    But in the end I found something believable, and, equipped with some extra reference, I started from a cylinder with 12 divisions (I hope to separate these into planks later). To get the right shape, I added a circle with the right measurement, positioned it in the middle of the barrel and scaled the mid section to meet the circle.
    Then I deleted the head (that's barrel jargon for you, ha) and the bottom and I added the Solidify modifier. Remembered to apply the scale (I always forget) and I ballparked the plank width (so much for accurate measurements). I thought about the hoops and realized that it might be a good idea to mirror the barrel on Z (I had to reset the origin to the centre to make this work). And so the barrel stave was born.
    WIP 2: Plank separation
    I knew I'd need some holding edges for each plank, but I didn't want to add them one by one, so I used a little trick. I added a loop at the bottom. Then I selected all vertical edges and bevelled them with one extra edge inside.
    I selected these extra edges and ripped them (with V). This didn't seem to do much, but when I added the SubSurf modifier and smooth shading, it started to look more like a barrel. (The modifiers are not applied, it's just that I'm showing the wireframe).
  • spikeyxxx replied
    shiennar Great! By using the Solidify Modifier, you already got the slant of the wood planks ends for free;)
    One easy way to separate the planks is to select all the vertical edge loops (in edge mode) and press V.
    Select a plank and press F to fill both sides at once (you'll need to have the F2 addon enabled for that to work, I think).
    Sorry if you already knew this, but others reading this might not;)
    spikeyxxx We must have posted at the same time :-) Yes, I ripped the edges - I rarely use it, but for some reason it hit me here as a good way of making the planks. I had a duh! moment with the plank filling, but when I went to check, I found out the solidify modifier had everything under control (we'll see if that's still true when I apply it later). Thanks for the tips, I need to check if F2 is now bundled in or if I need to get it - it's a great tool indeed.
  • spikeyxxx replied
    shiennar Yes of course! The solidify Modifier already does the filling. I forgot about that;)
    WIP 3: Adding hoops
    Next I added a circle, and extruded and copied it to create the three hoops. I temporarily disabled modifiers on the stave so that I could position the hoops correctly. Then, in object mode, I selected the hoops and the stave and copied (linked) the modifiers with Ctrl+L. Now the hoops also have thickness and smoothness.
    I didn't add the holding edges at this point, because I wanted to add more detail to the hoops. I ripped the top hoop at one vertical edge. Then I moved the cursor to the center of the hoop and I changed the pivot point to cursor. With this setup, I was able to scale (with Alt+S) and extrude+rotate the edges so that they weren't overlapping. I finally added the holding edges and moved the vertices at the end of the hoops so that it looked more like it was truly welded.
    After that I modelled a simple rivet. I enabled snapping to faces (affecting rotation) and I switched to "Normal" transformation orientation. Then I snapped the rivets onto the hoops and moved them in the Z normal direction. At the end I joined them to one object and mirrored them exactly like the hoops.
  • spikeyxxx replied
    shiennar Cool! That's almost exactly the same method I used for my rings...
    As for stating the obvious: at some point, apply the Z- mirror, so you can rotate the hoops a bit more randomly. The mirroring is too obvious now.
    shiennar I’m learning a lot by reading about your process :)
    WIP 4: Adding top/bottom and a rack
    To create the lid, I added a new circle. I had to experiment a bit with the number of vertices (16 proved to be what I was after). First I filled it with a single face and then I inset it - to get nice shading later. I deleted the middle face and used a grid fill tool with span of 1 to create the planks. Then I selected all the loops and bevelled them with 1 extra edge. To select the middle edge only, I found out the quickest way was to press Ctrl -. Then I ripped those edges again.
    I also applied the mirror on hoops and rivets and made small adjustments to make the mirror less obvious. This is what the barrel looks like now (with MatCap):
    Next I'm going to create a couple more items to put together a simple scene.
  • spikeyxxx replied
    shiennar Looks good! Way to go Katerina!
    WIP 5: Shaping the scene
    I added a couple of seats and a barrel rack. I thought it would be funny if the seats were created from re-purposed barrels, so I... did just that. The rack was a bit of a nightmare, though. I experimented with different shapes - this one has the bottom indent created from a separate circle (so the indent doesn't match the top one). I'll try to add couple more things tomorrow.
    shiennar nice scene! Maybe lower the table barrel a bit? If you are sitting so low it’s hard to reach so high for your drinks ;)
  • spikeyxxx replied
    ssmurfmier1985 Actually I think the seats need to be a bit higher. Bar stools and the like tend to be quite high.
  • Ben Reichel(notcastanza) replied
    I look forward to where you go with this.  Will you be tapping the barrel on the stand?
    WIP 6: Adding final touches
    Next I'm going to add a tap (as notcastanza correctly guessed). For these kinds of shape I like to use the screw modifier. It's almost like magic. You add a plane, merge all the vertices into one and then extrude your profile shape. Add the Screw and SubSurf modifiers and voila: a tap base:
    The good thing about this is that it's non-desctructive - you can change your profile as much as you like.
    The last object I made was a tankard. And of course I used the barrel base (but I created new hoops and the handle). The handle didn't come out as I imagined it, but oh well.
    Homework Week 1
    And this is all the elements brought together. I quickly added a few grass blades and trees to fill the scene up a bit. The trees are created from metaballs (that's a special object that fluidly merges with its neighboring metaballs, so you can quickly create organic looking shapes).
    I was struggling a bit with finding a good angle to present the scene, so there is an overall one and a close-up.
    ssmurfmier1985 and spikeyxxx I both scalled down the table and raised the seats. :-) I should have added a human for scale, when I was creating the various parts (eyeballing things usually gets you into trouble...)
