Lots of details to go, but the overall shape is done, at least.
Edit: It even mostly works with "Jake" sitting in it.
Edit the 2nd: Getting the front fork rigging done. I'll be happy when that works properly, including steering. (The pistons already work when the wheel is "in line".)
Getting there now. The center stand needs a bit of work, I want to texture my cables, and maybe tweak their placement a bit.
I could mess with the "2nd block" of the transmission a bit more, but it's only visible from directly underneath.
What I really need to do is get my rigging finished.
This is *nearly* done, at least for a factory finish.
I do need to tweak the materials so I can go from factory finish to a worn finish and adjust between the two.
Nice.
If you don't name it, I will. This is The Judge Dredger, Model W.
Heh, nice.
This is more a futuristic "Full Throttle" cycle.
