Want to try this Exercise?
Check out the about tab below and start learning on CG Cookie today.
Get Started
crew
  • Software:Blender 2.73  ·
  • Difficulty:Beginner
Rules of the Exercise
  • 1
    Use mesh tools learned in this course to modifying the provided primitive objects.
  • 2
    Modify only the three provided mesh primitive objects
  • 3
    Submit your finished exercise to https://sketchfab.com
Applying what you've learned
Learning how tools work and understanding them is one, actually applying those tools to real projects is a very different story. Now that you've learned the fundamental mesh modeling tools and understand how to work with mesh objects and data in Blender it's time to put what you've learned to the test.
Your challenge
In this exercise you're challenged to modify three default primitives using nothing but the tools you've learned in this course. Using just these tools you can create most anything from primitives; as an example here is a before and after comparison of these primitives:exercise01_starting-pointexercise01_end-point Your task is to modify these primitives, adding detail, form challenges, etc. Use your imagination. Once you have completed the exercise upload your result to https://sketchfab.com and then submit your result via the Submit Your Exercise button to the top right.
