BC1-1908 Homework - tobles
Collaborations
Homework topic
  • jamesley replied
    If you have applied a subdivision modifier, you can reduce the level of subdivision to get a low poly I guess
  • Thibault Caradec(otowa) replied
    As Kent mentionned during the stream "low poly" is not about a number but more about the modeling technique and style.
    I'm pretty sure the chest of the course can be considered low poly and has a much higher vertices count than that.
    ttobles  that looks lo poly to me.  Looking pretty good man.
  • Kent Trammell replied
    All good advice in here already. Your axe qualifies as low-poly in my book. However your current edgeflow (wireframe pattern) is very gridlike. You could be more optimal if your edgeflow followed the shape better instead of being limited by grid-form:
  • silentheart00 replied
    It could be considered low poly, but I can see ways for it to be improved.  Kent definitely has it covered with the better edge flow.  Remember: surround your important edges with edge loops and think about how you want the edgeflow to go.  Perhaps a good thing to keep in mind is only adding an edge loop if you absolutely have to for better form.  Maybe that'll help you to think in a very minimal way.  Give it a shot, see what happens.  Good effort so far.
  • spikeyxxx replied
    If you want to go for low-poly, consider not using a Subsurf Modifier, but Smooth Shading, with Sharp Edges where needed and Auto smooth turned on. Together with Kent's suggestion of edge flow, you could get a good result with very sparse topology.
  • Aaron Rudderham(thecabbagedetective) replied
    To reiterate what's been said here, if you're going for low poly a Subsurf modifier is probably best avoided. You can "remove" any subsurf you've applied by adding a decimate modifier and switching it to un-subdivide. It's not perfect by any means and won't bring your model 100% back to its original base but it will definitely get it lower poly if that's what you're looking for.
  • tobles replied
    Hey,
    thanks to all of you, I appreciate your answers. I'll clean than up how @theluthier mentioned it.
    Just to get the rumors out, I haven't used subsurf, I produced that pile of vertices by starting out with a plane and extruding it. I should've known better, but somehow my brain just can't use what I've learned about good topology :D
    Update:
    Dang it, I've lost the roundness of that blade. Has somebody an advice about rounding it up, without creating more loopcuts? (Shade smooth and autosmmoth are both turned on)
    Cheers
    tobles
  • spikeyxxx replied
    ttobles You will need at least two more edgeloops like so for instance:
    Then select the blade edge and (make sure you have Looptools addon enabled!) Looptools > relax.
    (Right click for the specials menu, or if you use right click select, W)
    Looptools can also be found in the N-Panel under Edit.
  • tobles replied
    Thx spikeyxxx. It's good to know you are out there, kind of relaxes me :D
  • Ingrid Frank(Fide) replied
    An axe, very nice. I´m looking forward to your progress!
  • tobles replied
    Hey ho,
    a short update of my progress:
    I made an insert to the axe head and put some runes in/on it. For the next steps i'll try to polish those runes up, so they won't look like Lego-bricks ;) After that is done, I'll turn my eye on the shaft.
    Spikey already pointed you in the right direction 👍
    Here's a couple other tips: First you can use the "percentage" mode of the bevel tool to smooth out your low poly curve shapes easily:
    Second, you can use a subdivison surface modifier to smooth the whole mesh and then apply it. It still counts as low-poly since the smoothed version becomes the new base mesh:
    Anyhoo, you're progressing very well. Keep up the good work!
  • tobles replied
    Moin moin,
    here is my actual progress:
    I redid the ornaments, added some straps and reshaped the shaft... for ergonimical head-splitting I guess :D
    If someone would be so nice and have a look the lower wrappings for the grip. They look strange to me but I can't figure out why and how to change it.
    When submitting for week 1, do we post a screenshot or some rendered stuff?
    Greetings,
    tobles
  • spikeyxxx replied
    ttobles Looks good! Some strange shading artefact at the bottom of the axe head...
    The lower wrappings do look a bit strange, but imagine them textured; I think that will solve the problem (at least I hope so!).
    As for submitting week 1, a screenshot is perfectly fine, seeing that we haven't done any texturing and shading yet....
  • tobles replied
    Can somebody pls have a look at the metal fasting that holds the axe head on the shaft and tell me if they are too tiny and should be bigger, wider or longer etc. ?
  • Jake McCluskey(Ghujelk) replied
    ttobles I think the size is fine visually, however if I think about the sort of functionality of using that axe there's the wrapped portion of the handle where you would hold it when you wanted to really chop something and get a large amount of force behind the swing, but when you wanted to use it for finer more precise chopping work your hand would be up around the section you added the fasteners to which could feel uncomfortable in the hand.
    Looking at various reference images online, a lot of other hand axes that incorporate pins to help fix the head to the handle do so by drilling through the head directly.  If you wanted some elements visually where the fastners are, maybe consider extending the cord or wrapping you already have there, or repeating the wrap you have near the bottom of the handle near the top.
    Maybe something like this.
  • tobles replied
    Homework Submission Week 1
    For this week, my goal was to model an axe with barbaric/viking/germanic style. I therefore put some runes in an inset on the blade and added some leather straps around the axe head and the shaft. I decided not to add any dings, dongs or scratches to the axe since I want it in a pristine state.
    In case of grading, I can provide the blend-file if needed.
    Cheers,
    tobles
    ttobles This turned out nice!  I'm getting some God of War 4 vibes.  Makes sense, since they're both about Celtci/Norse gods.  Good effort!
    ttobles Your axe turned out great! It makes me want to watch The Patriot. I like the form, structure, and details. The only notes I have to offer involves the leather strap/cord wrapped around the handle + axehead:
    • The straps in green look appropriately taught while the ones in the orange box feel oddly loose. I recommend making the lose ones taught as well.
    • The straps in the magenta box feel bit strange to me. Like they're supposed to be a continuation of a single wrapped strap (attached to the orange and green portions) but it's not connected. It looks more like a broad weave pattern of some kind. Perhaps that's the intention but I expected it to be a continuation wrapped around the handle, like a thinner-width leather strap similarly wrapped as the grip of the axe.
      Ignore me if I'm off in left field 😅 Regardless, you've earned an A for sure!
