COLLAB2021 - Team CRAYSONS - House Exterior (Front) Assets
CALLING ALL CRAZY CARPENTERS & MASONS!
Helpful Links to get you started and keep you engaged:
"The Google Sheet": a.k.a the CGC - 2021 Collaboration - Assets List, Assignments, Submissions, and Grading
2021 Collab Request Access to the Shared Google Drive: How to do it.
Also here's quick link to Email Kent: kent@cgcookie.com
2021 Collab Shared Drive: Quick link if you like going there on the web.
Google Drive Desktop Application Install Link: Download for Google Drive Desktop Client
2020 Collab Syncing YouTube Instructions: How to sync up and make a link to a Collab Shared Folder (remember the shift + z trick)
2020 Collab Syncing Forum Discussion: Helpful resource to 'Drive' the concept home for you.
Discord Home away from Home:     (unofficial way of collaborating if that's more of your cup of tea)
House Exterior Front Team Text Channel Invite Link: https://discord.gg/kz2Mkhet
House Exterior Front Team AV Channel Invite Link: https://discord.gg/b3rh2Fk4
As always this CGCookie forum is the place for all Free Crayson Team major updates.
    You're the glue that holds all of this spice-mortar together Jake
  • qpola replied
    Hi All, I just had to answer this call. :)
     Assuming the list doesn't grow more this looks to be a great starting lineup!
    Here's the full list of team members as of now:
    ttat , andybegg , nnavik , jakeblended , matbev , oonelombax , @donsoarese , cclementk , nathangarduno , tthe3dbanana , interuse , sstclark , bbryandr , ccooly , undiscovered , konstantinosk , blanchsb, duerer, hapit ,  llegobenj , chbug  hadiczech , beefkeef
    Also FYI the discord server is also up and running. Both here and there are places to collaborate. We'll try to keep official announcements in this forum but you are welcome to work together in our own text and voice channels dedicated for our team over there if you'd like. I'll place a semi-active role in both locations.
    Discord Home away from Home:     (unofficial way of collaborating in real time if that's more of your cup of tea)
  • Fred Gobry(chbug) replied
    Alrighty, I'll let you know once I have begun in earnest. Work to wrap up first...
  • Don Soarese replied
    Craftsman Donsoarese reporting for duty!
    And a salute to the team.
    @donsoarese welcome to the crew! Looking forward to working alongside you.
    Maybe the asymmetry  is needed to match the artwork?
    hapit You're absolutely right! I don't know whether this was intended by Vadim harbinger_ua but this is how I could make it fit. We will have to wait for Kent's @theluthier blockout to which we all can align our parts.
  • Ben Nicholes(legobenj) replied
    Any ideas why my chimney bool may not be working? When set to union, the cube fills up fine, but difference is doing nothing. I tried it both with the modifier and in geometry nodes and neither worked.
    llegobenj That is strange. I wouldn't think it would be mod stack order if Union is working.
    Have you tried toggling the boolean exact versus quick method in the Blender preferences?
    I'd try the difference out on something simpler to see if you can nail down the behavior first, perhaps and troubleshoot the process.
    Alright I have been on the research mill and have come to a fairly certain conclusion regarding the location and placement- orientation of the Cornerstone.
    But first, a little background history:
    "In the past, buildings were designed and built in relation to certain astronomical points of the compass. Ancient cultures believed that the position of heavenly bodies regulated life, fortune, and success; therefore, Cornerstones were commonly placed facing the North East because it was thought this location would bring harmony and prosperity to the building and its owners. The ancient civilizations often performed a ceremonial ritual when the Cornerstone was placed." as found here: https://www.billwarch.com/blog/the-little-known-purpose-of-the-cornerstone/
    Based on Omar's blueprint & the shadow direction given from the Sun (travels from the East-to-West) it would appear that the Cornerstone would go here (The North East Corner) which makes sense for the front of the house. It'll go at the base of the foundation (probably covered):
    I covered this with the Spice Baron leaders and I am pretty certain this is the location but I'll get confirmation tomorrow.
    The next major question is what do we as a group of Free Craysons place inside the Corner Stone to place as a tribute? I'm thinking either an insignia from the team or an object that represents us (like a construction/mason tool(s) perhaps one for the carpentry and one for the masonry?
    We'll want to also allow each team to place a tribute to bless the building with.
    Doing a quick reality check : I'm considering the foundation stones (H) to form the perimeter of the house, with the interior being hollow with, say, a wooden floor being the visible part inside. Does that sound reasonable? The alternative would be to extend it to the whole surface, but that would seem like a very difficult thing to construct in practice, to get anything flat.
    Here's the snippet from the live stream regarding the naming convention for our files:
    So, our team files should look something like this, agreed?
    house-ext-front_asset_##_username.blend
    For mine it would be:
    house-ext-front_foundation_01_blanchsb.blend
    How does that sound?
  • spikeyxxx replied
    Sometimes it is just a matter of checking the Self checkbox. (there are other things that can go wrong, but try the easy ones first).
  • qpola replied
    Hi everyone! Qpola reporting for some chiseling duty. I will attempt to contribute to the wooden beam asset and was wondering if there is any way to get access to the high res reference picture, which Kent talked about. The one that is on the Google Drive.
    jakeblended and matbev let me know if you want to align on the work for this asset.
  • onelombax replied
    A quick note for everyone doing the wainscotting part, you might want to search references using the keyword wood board sliding exterior and if you're looking for wear and tear, try reclaimed wood.
    Oh and I found this interesting approach to wood sculpting that I will be trying. (For anyone wanting a strict blender pipeline, the treasure chest course gives more than enough to go on).
    See you soon ;)
  • Mat Bevan(matbev) replied
    Hey qqpola yeah i think thats a great shout there. lets have a think of a way we can do this.
    heeeere we go. cant wait to get started on this
    llegobenj spikey may be on to something there.
    qqpola if you have sync'd the file then the image is located here:
    Google Drive\CGCookie Collab 2021\SPICE-VENDORS-HOUSE\IMAGES\REF\Vadim-Zaytsev_Spice-Vendors-House
    Does that help?
    Woah that is a great question.
    There are blueprints on the Collab Google Drive that Omar has drafted up already.
    I believe there is a sub level already considered in the design.
    Our job is to try to make sense of all of that. We may need to collaborate with the House Interior group to get clarification on the interior but my quick though is let's focus on the exterior perimeter. There's plenty to tackle there.
