Gallery
Minimalistict Luxury Bathroom Final
Used Blenders cycles render engine at 500 samples and blenders compositor no gimp or photoshop used. Please leave a comment to help me improve CGI
2 Comments
Add a Comment
  • thanks for the input I was thinking the same corners are too dark, this happened after color correction. The cliff is a image texture with normal, reflective glossy and displacement maps.
  • Nice case for use of perspective to lead the eye through composition. The "beams"(?) near the ceiling lead the eye towards the center of the image, with sinks and the bath mirroring that action from lower down.
    The whole piece seems to be too dark for comfort. If I was in that shower I'd expect monsters crawling out of dark corners. Was this your intent? :)
    That said, the light that is there highlights the shower area well; perhaps, move the camera closer to make that area more central and reduce the darkness around corners?
    That would make the - awesome! - cliff even more prominent, too! How did you make that? I really like it.
    Well done, keep it up!
