When the Blender you're using is different from the Blender in the video...
One of the best parts of being a Blender user is how quickly the application gets updated! One of the worst parts of being a Blender instructor is how quickly the application gets updated.
At CG Cookie we're very aware of this problem. If a course is more than a couple months old, chances are there's a tool name or setting that's been changed in Blender since. Such changes technically make the course "outdated" with wrong information. We get comments all the time from confused users asking why the video has a different tool or setting than the Blender they downloaded yesterday.
We hear you and we completely understand how frustrating this is. Blender's learning curve is steep enough as it is. The added difficulty of inconsistent software versions shouldn't be your concern.
What can we do about it?
The answer came to me in a dream, written on a scroll of seaweed, delivered by the Princess of Hyrule herself...Ok, not really. But a simple solution dawned on me recently:
Always use the same version of Blender that you see in the video.
All previous [official] versions of blender can be found here and each of our courses note which version of Blender the course was recorded with. Using the same Blender version ensures that UI buttons, settings, features, and addon compatibility are consistent. That way you can smoothly follow the videos and not be distracted by inconsistencies.
The important thing to learn from us is the WHY, not the HOW
The Why is the concept and principles of digitally sculpting forms. The How is "press the Dynamic Topology button and set the Detail size to blah blah blah". Not that the How isn't important, but we've always pushed that its not nearly as important as the Why. The Why is what translates from 3D package to 3D package and makes an artist adaptable.
Take Piero, For Example...
I've received several comments on my Piero shot film course about software inconsistencies - and they're entirely valid. The course was recorded with Blender 2.66 and a lot has changed since then. Though we should clarify that a lot has changed with software specifics, not much has changed in terms of workflow. Therefore, the How has grown a little blurry over the years but the Why of Piero is still relevant. Honestly, if I re-recorded that entire [massive] course again, 99% of it would be exactly the same. Only a few tool names and settings would be different.
All that to say: If you want to get the most out of our Blender Education library, use the same version of Blender that you see in the video.
But if I am using older software, isn't this putting me behind the curve?
Trust us, we're doctors.
Understand that this recommendation is not a symptom of us relaxing our commitment to deliver the most relevant Blender/3D Education possible. That commitment will never relax. We're constantly creating new content with the latest version of Blender, holding tight to the cutting edge. If we keep a course in the CG Cookie Library it's because we stand beside its relevance regardless of the Blender version used.
The recommendation we offer in this post is simply a solution to the confusion that I read about frequently in comments and emails. We want our users to maximize the value of their membership. Think of it in terms of context: Respecting the context of a Blender 2.68 course will enable you to get the most out of it.
Happy Learning!
Images from the Disney/Pixar short, "Night & Day"
Â
A friend recommended this platform recently, so I decided to create an account and see how straightforward the setup process would be. The interface guided me through each step clearly and there were no confusing instructions along the way. Everything worked as expected and I didn’t need to repeat actions multiple times. By the time I completed everything, I felt that https://91clubz.net/">91 club register offered a much better experience than several similar platforms I had tried before.
https://awlyaaeducationsdz.org/">Awlyaa Education portal is a useful platform for Algerian parents to check students’ results and school information online. It saves time and improves communication with schools, but the site can become slow during result periods due to heavy traffic. Overall, it is a good step toward digital education services in Algeria.
I am just starting out here so this is my first day. I am currently on Blender 5.1.0 and I was wondering, even if I would use my current version to go along with the tutorials. I would think that these small changes, like a tool that got renamed or put somewhere else, might actually help me to focus less on the how, but more on the why things work the way they do. Since it breaks away from just following the instructions and makes me look for a solution to the tool I can't find. Of course this increases the learning curve to a degree, but I think it would help me get more familiar with the tools and their purpose, sure I will hit a wall that might take me a while and I might switching to the version of the tutorial later on. I haven't really started any of the courses yet and I will get right back to my basics course. I just wanted to voice this point of view in case it might benefit someone else.
Kage, Blender file formats are not necessarily backwards compatible depending the the versions you're going between. It's usually pretty good at forward-compatibility. I thought you might want to know that before getting in deep on a tutorial and then deciding to downgrade your version and have to start over. That said, I did take the approach you mentioned for the PANELS course, it did add some extra challenges but it was worth it as the Grease Pencil had some big changes.
Great article Kent. Absolutely adore the last thumbnail! That short is still one of my faves I believe I have come to the same reconciliation between versions. Ah...peace at last. Why? Because we understand the WHY (the theory of) it. You can memorize 3-squared is 9 all day long, but if you know "why" that is the result, you OWN it! This is huge for teaching music (especially) to young kids. The skill of utilizing clever mnemonics is the KEY TO ALL TEACHING. Perhaps this will be my first long-form Blog.
Great article Kent! Everyone joining the Blender community here at CG Cookie really should read this post. I agree on your proposed solution. CG Cookie already gives us the users the feedback to know what version is being used, so it just takes a little commitment on our end and willingness to setup and use the previous versions, which the Blender foundation makes easy to do through their release history.
If there's one thing that really, really struck me about your post, and what everyone should understand (specially 3D and Blender newbies) is what you said: THE IMPORTANT THING TO LEARN FROM US IS THE WHY, NOT THE HOW.
I could not agree more. This is such an excellent point! It's not what tool you use, it's understanding how that tool works and the principles behind how it works.
I will be teaching a beginners 3D course at the University where I work at this fall; naturally I will be using Blender. THE WHY, NOT THE HOW is something I will be stressing repeatedly and will try to convey with every classes I teach.
Thanks Kent, keep up the great work!
Haha good analogy. You get it, Omar!
Thanks for that :)
Thank you, Grady!
I started in Blender 2.63 and I feel it is 98% the same in the overall Blender vibe. Of course Blender has improved so much but I mean it in a James Bond kinda sense, were the actor changes over the years but it is still the womanizer, gadget guru, car loving James Bond.
this type of coverage and such is what sets Cookie apart from the rest...
Good job guys, keep it up!!
:D
