The keyhole created visible triangular seams
I'm not sure if I did something wrong or just got unlucky but when I cut the keyhole, it left very visible triangular seams. I tried to hide them as best I could during the 'banging up the metal' portion, but I can still see them... :(
  • Kent Trammell replied
    Can you post an image of what you're seeing?
  • Karen Trevino(ketre) replied
    Hi, I was trying to get a smooth circle cut out on the mech I did.
    I had to add in alot of loop cuts and supporting edges to get mine. I'm not professional by any means but I do understand your frustration. As you can see in the image below I had to do alot to smooth mine out.  I remember doing that circle on the chest, it was alot easier than what I did with this one.
    It came out pretty good considering I was going for a low poly count.
  • yomimoto replied
    when you accidentally duplicate two edges under eachother it creates a visible black line on the mesh
