Why doesn't my UV unwrap have any color? It is outlined in white with no fill color.
posted to: Laying Out UVs
My UV unwrap is outlined in white but has no fill color.. not green, red, or blue. What does this mean and how do I amend this?
  • Kent Trammell replied
    Hi panthra - Could you post a screenshot of the issue you're describing?
  • Kelly O(panthra) replied
    I have tried Googling why my UV unwrap turned out this way but I haven't found a solution.
  • spikeyxxx replied
    This is perfectly normal, O Kelly. What colors would you like to see? If you want to see the stretching colors,(which I think you do,) you need to open up the right (N-)Panel and enable the stretching Overlay (under View):
    Thank you for this! It is exactly what I needed. I think I missed the step where we enabled the stretching overlay. Problem solved!
    +1 for spikey saving the day again. Don't worry panthra we have all done this a time or two.
    spikeyxxx saves many days around here
