Why isn't the hair simulation following the emitter object?
When I try to create a hair simulation in blender 2.82, the emitter object falls to the plane, but the hair doesn't follow.
  • spikeyxxx replied
    That's a (known) bug: https://developer.blender.org/T75105
    The Particle System is being replaced, so until then (hopefully 2.90) we will have to live with this...
  • syboots replied
    The fix was provided by Zijun Zhou at https://developer.blender.org/T58044 back in Sep 2019, so am guessing it was there in 2.8 or 2.9 alpha
    In 2.91 today, this can be fixed if Collision Settings on the active rigid body is set to the following
    Shape = Mesh; Source = Base.
  • spikeyxxx replied
    That's not really a fix, just a workaround. Bug still exists in 2.93. Will probably be fixed with 'Everything Nodes'.
  • syboots replied
    My bad.
    Good to know that. Thanks.
  • spikeyxxx replied
    Don't get me wrong, it's a good workaround, but it's just not how it's supposed to work..It used to work fine before 2.8:
