the sculpting is not showing ...
hi,
i followed everything but in 3:06 my sculpting is not showing at all. what I'm doing wrong? I'm using blender 2.82. Thanks
  • Kent Trammell replied
    Are you sure the object is selected as the Active Object whenever you switch to sculpt mode? It looks like it is based on the outliner, but the way you can know this is if it's outlined in a lighter orange color in Object mode.
  • spikeyxxx replied
    You have a Modifier on your Cube. My guess is that that's a Subdivision Surface Modifier. That needs to be applied! There is also a warning in the Modifiers Tab:
     Apply the Modifier  and try again.
    spikeyxxx with the eagle's eye 👁️
  • spikeyxxx replied
    And just in case you get confused; here's the 2.82 version:
  • heinzmezagmail-com replied
    you're right. I forgot to apply the modifier. now it works.  Thank you!
  • zsavior replied
    Just in case somebody looks at this question, because they can't figure how to click apply. In Blender 2.9 for some odd reason in the modifier tab, the apply button is gone. Click the arrow next to the camera which is the render button to get the option to click apply.  Now when you go to sculpt mode the brushes will work and the warning message will disappear.
  • spikeyxxx replied
    Or just hover over the Modifier and press CTRL+A to Apply.
    If you want to Apply all Modifiers on an Object at once:
    This will apply all the modifiers. If you find yourself using  'Convert to' a lot (like I do), you can put it in your Quick Favorites...
  • zsavior replied
    Thanks for this info, it's really helpful.  Did not remember Ctrl-A short cut.
  • spikeyxxx replied
    CTRL+ A is used for applying in several cases (e.g. Object Mode > CTRL+A > Apply Transforms: Scale, Rotation, Location, etc)
    That makes it easier to remember ;)
