Cylinder unwrap help
Hi everybody. I want to map a teture on a cylinder, made the seams but the texture gets a cut on another edge, where I dont want any.. What am I doing wrong? thanks
  • polyrom3d replied
  • polyrom3d replied
  • spikeyxxx replied
    Well, my guess is: as you've used a Cylinder Primitive, that already has  UV's on it by default:
    when you put Seams on it, it will still use the 'old' UV's, unless you Unwrap it again with the new Seams.
    But maybe I completely misunderstand your question...the screenshots don't help me understand the problem...this is just going by the text..
  • polyrom3d replied
    but i unwrapped with new seams...
  • spikeyxxx replied
    You know that you have scaled the X and Y by 2, don't you?
    That means the Texture will be repeated twice around the Cylinder, thus giving two seams...
  • polyrom3d replied
    it always creates multiple seams, even when scale is 1
  • spikeyxxx replied
    Maybe it's something like this?
    The blue line is where the left and right side of the image  meet and win a not seamless texture, that would be a visible seam..
  • polyrom3d replied
    I have a material with an image texture on it. I tried smart uv project, or cylinder project. But with every projection, the seams are always at the same spot
  • spikeyxxx replied
    Could you make a Screenshot with the 3D View (Cylinder in Edit Mode)and the UV Editor(with the image) open?
  • polyrom3d replied
  • polyrom3d replied
    I dont have the image in image editor, its just as a texture node in material
  • spikeyxxx replied
    So, open it up in the UV Editor (or in the Image Editor, should work as well); where it says Untitled, change that to your uv3.png (it's in the dropdown list: down arrow left of the name)
  • spikeyxxx replied
    Oh, and put the 3D View in Rendered Mode, so I can see the texture on the cylinder
  • spikeyxxx replied
    And Unwrap it with your Seams, not with Smart UV Project.,..
  • polyrom3d replied
  • polyrom3d replied
    And now? I am very happy that you help ;) thanks
  • spikeyxxx replied
    The image underneath the  left rectangle in the Image Editor is being projected on the 'middle' part of your Cylinder:
    At the moment this is mostly empty space..
    Change the Image Editor to the UV Editor, so you can fit the rectangular area around the text.
  • polyrom3d replied
    Thanks, it worked ;)
