Extrapolation Mode through Channel selection
posted to: Square in Square
Hello!
I animated this easy enough, but got stuck on Extrapolation Mode.
Right clicking in the Graph Editor, on Object Transforms channels, brings up the Extrapolation Mode menu, but they're grayed out ( = wild goose chase).
It's shown how to do it @5:40 in the previous Looping Ball video though derr
- In Object Mode
- Select the Object
- In Graph Editor
- Select the Channels
- Channel button (above the Graph Editor)
- Extrapolation Mode (Shift E)
- Winning
I'm curious how right click selection vs Channel are different to Blender, and how can I find out what it wants when I encounter grayed out menus like that?
  • Wayne Dixon replied
    If you are using Right Click Select like I am, the context menu is enabled with the W key.
    So it works in a similar way after that.
    With the Greyed out options, do you have any channels locked?
    It seems there might be a small disconnect with the behaviour and the UI.
    If a single channel is locked - it is not greyed out in the context menu or channel menu, but it does not work (because of the lock)
    Whereas, if the entire group is locked - both the menus are greyed out.
    Which is more intuitive imo
