Stuck on how to model Guitar Strings
I'm currently working on modelling this guitar however for the last couple hours I've been unsure on how I could model the guitar strings. I've tried a path curve however I was unsure if you could solidify it to make it look round like the string's are suppose to.
Any suggestions on how I could achieve this would be greatly appreciated!
  • Michael Mirn(michaelmirn) replied
    There was a video that might be useful:
    https://cgcookie.com/tutorial/creating-procedural-chain-links-in-blender
    But maybe you should mimic its geometry with texture/displacement map?
  • danielnvl replied
    Thank you for the reply, appreciate the help! I'll try both suggestions :)
  • spikeyxxx replied
    To just make it round, you can use a Path, or any Curve and adjust its thickness and resolution here:
    For the thicker, coiled strings, you could use the Screw Modifier:
    Followed by a Curve Modifier:
  • danielnvl replied
    Thank you very much, I'll do this tomorrow morning :)
