Final render looks different than preview render
Hey! A few days ago I finished the Low Poly Rocket course, but when I rendered the animation, I realized that something was wrong. I re-renders only this frame and the difference is obvious. One is the rendered preview and the other is the already rendered frame. I have been looking for people with the same problem but have not found a solution. Hope someone can help me. Thank you.
  • Michael Mirn(michaelmirn) replied
    Hi, @johnisland
    It is too bad that you've cropped thatright side of the screen. Specially Output tab:
    Check up your output settings.
  • John Island(johnisland) replied
    Oh I'm sorry. I think that is fine.
    Maybe where the problem is in the particle configuration. But it should not be different in the preview render. So sorry, I'm newbie in this.
    I am seeing that it's as if Blender was rendering an old configuration. I have cleared the cache and try different values, with eevee but it still continues rendering what he wants haha. I will do it again to practice. Anyway I would like to understand why this happens.
    Hmm, I'd like to understand that too) jjohnisland,  can you share the sourse file?
  • spikeyxxx replied
    I've seen this many times with this course. For instance: https://cgcookie.com/questions/11637-why-is-my-smoke-spreader-not-working-when-i-render-animation
    Did you bake the particles?
    I know you said you cleared the cache, but I'm  not sure what you actually did there...
    Here is the file. But I don't know if you can load all the data correctly. Again, I am very awkward even in these things. Thanks for the help. spikeyxxx yes I cleaned it from there but still I have the same error.
    Thanks, jjohnisland.
    Firstly, I thought that there was some problem with your camera settings (because of that landscape orientation). Me bad, sry(
    I've downloaded the file and did two things:
    1) Delete all bakes.
    2) Bake all dynamics.
    Here is the result:
  • spikeyxxx replied
    michaelmirn, that is not the result it should be... I've tried that, because that was also my first guess, but:
    jjohnisland I've tried all the other usual suspects, that I could think of and also some things that I didn't expect to make a difference;
    the result stays the same...
    Like I said, I've seen a few people with similar problems with the smoke in this course, but yours seems to be something else..
    I give up for now, but will look at it again tomorrow...
    God, thank you both so much for this unconditional help. It's a weird problem, I guess doing it again will be fine. So it isn't too urgent. Anyway, as I said in a previous post, it would be interesting to know what the problem is to solve it if it happens again in the future. I am using Blender 2.83, maybe it is a bug? I don't know. Thanks again to both of you for getting involved <3
  • spikeyxxx replied
    jjohnisland, I do not think it's a bug, although that is of course a possibility...
    I've tested it in 2.80, 2.83 and 2.90 and the result is the same every time.
    It is always a pleasure to solve a mystery! Too bad this one hasn't been solved yet tho :(
    And it is weird. It is like there are two different scenes for rendering and viewport.
  • spikeyxxx replied
    Yep, It's somehow not rendering particles that are 'too old', but rendering them in the viewport...
  • spikeyxxx replied
    jjohnisland I have found what is causing this, but I do not know why. It is caused by the keyframes on the Particle Lifetime (where have I seen this before? I'm sure it was with this course...). Remove the keyframes and you're fine, at least the render is the same as the preview...but now both are wrong...
    I removed the Motion Blur and the Denoiser here for testing purposes and moved the black flag on the Colorramp (for Particle size) a bit to the left to compensate a bit for the now longer lifetime of the smoke.
    I'd guess that this is indeed a bug, but the Particle system is being completey re-written as we speak, so I wouldn't report it.
    You're right, it was that! I undid a lot of things, but that's the only thing I didn't touch (facepalm) haha. I suppose undo and redo will fix some issues right now for being so new to this. At this moment I'm in another course that is beyond my level, this rocket course surprised me because I was still quite clumsy. I will do it again soon and upload it here. Sorry for not seeing the message sooner. Thank you very much to you and to michaelmirn really!
