2.83 search tool not replicating a result after using it?
Does anyone else experience this issue where using the search tool to execute a command again does not populate a result? I'm only having this issue in the official 2.83 release so far. Haven't checked 2.9 yet
For instance I search for knife project and I get the results I am looking for. Then I activate the search tool and it defaults to Knife Project (the entire legit name of the tool) but the search results are completely blank.......???
  • spikeyxxx replied
    Hi Shawn It seems you have found a bug, this typically only happens with the Knife Project...(I couldn't find any other operator with this behavior)
    You can of course assign a shortcut to it (SHIFT+K is free, when you haven't used that yet).
    Or you can check Developers Extras in your Preferences:
    And then in Experimental use Menu Search:
    This last option is now default in 2.90, so the problem doesn't arise there (the developers must have noticed something was wrong...)
    I agree I am currently narrowing it down to knife project specifically. I wonder if it's not in 2.9 then I probably don't need to report it then, right?
  • spikeyxxx replied
    I found (probably) related bugs already reported, so no, I wouldn't report it. As it is fixed in 2.90, it will probably be changed in the first corrective release 2.83.1
    Cool, thanks spikeyxxx
