Hi! I forgot that I needed to create another polybook here! I wish typing spaces worked right now...grrr...
Anyway, my first thing to show is from the Digital Lighting course! @jlampel , here are the first two, sunny day (soooo sunny...I thought I had a less blown-out one) and nighttime:
Everything's so bright! o_o I made a sunset bedroom scene, and it was a little difficult with the sun looking a bit closer in strength and colour temp as the lamps! So I turned a lamp off. I used your sunset sun light from the addon, sky texture, and an area lmap that was kind of pinkish... I wanted to get plenty of light, but not TOO much of the window's reflection (oh, I put the sampling up on this to...about...200)!
That was so fun!! I have to continue with Eevee... Finally was able to finish the Cycles part! Augh!! And if I remember, I'll put more of my stuff up if/whenever I make stuff!
Great work Jazze :) , good to see you back! Keep up the good work :)
Thank you, frikkr !! :D Awwww, gee! I'm glad to be back! I'll try updating whenever I can. ^_^
Thank you, @jlampel !! Oh, it makes me feel so good to do some great lighting there! Now I feel like running through all my old stuff and seeing if I can make the lighting better. BUT I wanna finish the course, first. :D
