Extrusion only working on vertical edges
Hey there!
Does anyone know why when I move from Bevel to extrude along normals, only the vertical edges are being extruded?
Thanks!
  • Jonathan Lampel replied
    Hey, my guess would be that the difference is being in edge select mode rather than face select mode - the normals of the edges will be different than the normals of the faces and in this case could be pointing upwards.
    Hope that helps!
