How to compare renders inside Blender?
Collaborations
I googled this and got this answer, where it says it can be done in the UV editr.
I should select a different slot everytime I render. But where exactly do you I choose the slot? I don't see an option in the UV layout.
However, I was looking for something more like what I see in this other software.
My UV panel:
https://www.youtube.com/watch?v=MJg4GrxuLh0
  • spikeyxxx replied
    oogonzales use the Image Editor:
    The same options to choose your Slots are in the UV Editor.
  • spikeyxxx replied
    If you want this 'split screen effect'. you need to Save your Renders as Images and then use the Compositor:
  • ogonzales replied
    spikeyxxx thank you, man. I'll try this later, after finishing some work.
