Blending layers destroys previous layer. need help
Hey, I have a problem with painting the layers and blending them
When I turn fac to 1 I can see the transperancy and blending but when I turn it down then the base rgb becomes white and the transparency is broken
Can somebody help me? Cant figure out what I am doing wrong
  • spikeyxxx replied
    Hi Sergey, you should connect the RGB Color to the Color1 of the 'second' Mix Node and the output of the 'first' Mix Node (with the Opacity slider) to the Color2. Like this:
  • Serg (comicsserg) replied
    Ow totally missed this! thanks so much spikeyxxx !
