Artifacts on gpu render
Hi everybody. I get some artifacts when I render with GPU compute in cycles. When I render with CPU, its fine. 800 Samples. Even with 2000 samples, they are still there. Did denoising, switched off caustics, no volumetric scattering..
Anyone knows what it could be? I have a gtx 2070 max q.
  • spikeyxxx replied
    What kind of artefacts?
    When I Google gtx 2070 max q, I get Nvidia RTX 2070 results...
    In your Preferences > System > Cycles Render Devices, do you have RTX enabled?
    Don't know if that makes any diference; can't check that, I can't even render on my GPU; it's that old;)
  • polyrom3d replied
  • polyrom3d replied
    yes it is a rtx, sorry.
    Perhaps you could try turning off denoising?
  • polyrom3d replied
    no that makes no sense ;) thanks
  • polyrom3d replied
    Lol. did you see the picture?
  • spikeyxxx replied
    I did!
    I gather  you mean the noise...
    What does it look like on CPU?
    I do not know why there would be a difference between a CPU and a GPU render....
    In the 'old' days, before RTX, a CPU (and this is highly simplified!) would have Order(10) intelligent calculating units (cores) and a GPU would have Order(1000) 'dumm' calculating units.
    But they should still get the same result...
  • polyrom3d replied
  • spikeyxxx replied
    It might not make sense, but did you try it?
  • polyrom3d replied
    with cpu it looks fine
  • spikeyxxx replied
    I'd say, post a link to your .blend file here.
    Somebody might be able to figure this out.
    This is not supposed to be like this!
  • polyrom3d replied
  • polyrom3d replied
    this without denoising
  • spikeyxxx replied
    Looks way better without Denoising, would just need more Samples to get rid of the noise;)
    But I still don't know why it makes a difference whether you render on CPU or GPU.....
  • polyrom3d replied
    better? :p well that noise is huge
  • polyrom3d replied
    even with 2000 samples there is much noise
  • spikeyxxx replied
    Is there a difference in noise between CPU and GPU renders?
    If not, it looks like a GPU + Denoise problem, here are some suggestions (first one is a must):
    - Make sure you are using the latest driver!
    - File a bug report:
    - Try the other Denoiser (In the Compositor, use Denoise Data)).
    -Or render with CPU.
  • polyrom3d replied
    there is a huge difference in noise between cpu and gpu. latest driver is installed, other denoiser is way better, but still not as good as cpu render...
  • spikeyxxx replied
    Very strange!
    Like I said, unfortunately I can't render on my GPU, so I can't test how that is on my computer, but I've never heard of anyone complaining about a lot of noise on GPU renders...
    Could it have something to do with different tile sizes? Or is it maybe a RTX thing? Both sound very unlikely to me, but there really shouldn't be any difference between the two....(at least not humanly noticeable.)
  • polyrom3d replied
    thanks spike :)
