Set origin to 3D cursor mess up with Mirror modifier?
I'm trying to select a vertex, set the 3D cursor to it with `Shift + S -> Cursor to selected`, then when 3D cursor is in position, I shift to Object mode. In there I go to object and Set origin to 3D cursor, but my mesh gets messed up. What am I doing wrong?
Goal:
I'm trying to follow this tutorial, at min 5:37. The Goal is to put the origin to that vertext and move the selected faces using that vertex as point of reference.
Situation:
I've the 3D cursor in the desired vertex.
But pressing: "Set origin to 3D cursor" from the object menú, results in this:
Thank you for your help.
  • Karen Trevino(ketre) replied
    If you want to have the mirror show on the other side the origin needs to be in the "center" of the object.  You have set it at the top or side. Choose "center of object" when you set the origin. To get the origin to the center press Shift + C and then go to the Object Menu in Object mode. of the object. If not, it will go wonky.
  • ogonzales replied
    ketre I know that in order to get the mirror mod. woring the origin of the object must be at the center of the mesh.
    That is why I don't understand why when they move the origin the mesh is still in place. I'll see it again carefully to understand what's happening.
    the origin point that he speaks of is the cursor's position (rotation is from the cursor position)
    not the objects origin which is in the same position (0, 0, 0) all the way through
    1. object origin is in center
    2 rotation point set to 3D cursor makes edge rotate from there...
    hope this helps
  • spikeyxxx replied
    ketre is absolutely right!
    Well, it's not.:
    The mesh has shifted, so the Origin is again at the center of the Object, but that is because of the mirror modifier.
    Look closely at your third screenshot; it's got a 'hole' at the side!
    You could use an Empty or so as Mirror Object:
  • ogonzales replied
    Thank you, me1958424 ! that was it!
  • ogonzales replied
    ketre  spikeyxxx thank you both of you. I love your detail answers!!!
    Thank you again!!!
    I see where I missed it now, in the tutorial he placed the cursor in position then he said it changes the origin, I cant see that well on a small device, and it looked like you had changed the location of the origin.
