Stroke Curve doesn't seem working
posted to: Stroke Methods
It seems not working.
It doesn't draw the diagram to draw the curve line.
Is there any setting that enable/disable the drawing lines maybe?
I open the file with the start ball provided in the course.
thanks.
Reply
  • Kent Trammell replied
    Hi @mboggiosella - A unique thing with the line and curve stroke methods is that you need to hit the ENTER key to make the sculpt stroke happen. Am I guessing right that you're not hitting Enter?
    If I'm wrong and that's not solving your issue, could you record a screen capture GIF of what exactly is happening?
  • spikeyxxx replied
    mmboggiosella also note that you need to use CTRL+Right click to start a stroke and add new points when using the (now) default Left Click Select. When you are using Right Click Select, this would be CTRL+Left click...
    14 loves
  • Shay Spear(Spearshay) replied
    The curve tool definitely through me for a loop!
    For me, it was actually both of the above suggestions.
    I found that nothing would happen after i switched to the curve stroke tool and tried to draw a curve.
    Ctrl+right click added new points to the curve. Right click and drag allows you to move the points and adjust the shape of the curve.
    Hitting enter actually applies the stroke to the mesh where the curve is,
    This was a different tool for me, for sure!
