Small sand waves don't appear
Could you please help me - why can't I have small sand waves, like you have?
Like this one, in a blue oval:
What I have is:
My nodes are:
  • Kent Trammell replied
    You're really close! It looks like you followed my approach very accurately. The voronoi and mapping nodes have changed since this video was recorded, so that's likely causing a difference in the result.
    You clearly have a small, secondary 'wavy' pattern involved but it doesn't read like an obvious voronoi derivative the way mine does. It's hard too tell what's different just by looking at the node network.
    If you're willing to post a download link to your .blend file, I'd be happy to take a closer look at what's going on. The best way to do this is by uploading to Dropbox, Google Drive, or equivalent file hosting service then copy and paste the share download link here.
  • happybirthday replied
    Dear Kent,
    I also guess, that this effect is because of update of Blender.
    Here is my .blend file: https://drive.google.com/open?id=1cDCvpmiERlWAeF6Udo45H8HnWf_a-gir
    I would appreciate, if you help me to understand what to change in my nodes.
    Thank you!
    Thanks for providing your .blend file. Turns out to be a simple fix! The voronoi texture at the bottom is using the Color output instead of the Distance output:
     Using the distance produces the expected results.
