symmetrize bones, pole wrong direction
Hey,
I copied the situation from the video. everything works perfectly until I mirror the bones with IK constrain. Everything is correct but the knee is further out. what am i missing? thanks.
  • Kent Trammell replied
    Solution
    You need to adjust the Pole Angle in the IK constraint settings:
    Often I find with situations like this that the pole angle needs to be adjusted by 90-degree increments (90, 180, 270) but you can adjust it manually as desired.
  • gregvanstaey replied
    thanks for your fast reaction!!
    i have solved the problem
