When I try to shift ctrl alt s, it distorts rather than scales skinnier
https://gyazo.com/102babd4a6f6b503ab3aa6a5a7382ba9 Here is a gif of the issue and http://pasteall.org/blend/index.php?id=53059 this is the blend file.
Maybe I've accidently messed with the scaling settings or something. Hope you can help <3
  • frostheart10 replied
    The lid also distorts when I open it, is there a way I can fix that?
  • of Nodes & Noodles(gcs_dev) replied
    Hi ffrostheart10 , for the scaling issue, try using Ctrl-Alt-S instead. Shift-Ctrl-Alt-S gives me that shearing too.
    Thanks that seems to have worked :D
  • Wayne Dixon replied
    Yep - you are shearing it
