2.82 UV Sphere problem
2.82 and 2.82a Add UV Sphere dark and un-editable.... looked at 2.83 and its ok..... not finding any setting that would cause this problem in 2.82... any thoughts....
Thanks
  • spikeyxxx replied
    What do you mean? What is dark? The Align > World? That is supposed to look like that and it's not greyed out so it should be changeable.
    But what's with all these colors? Are you using an addon for the theme? Could that addon be causing problems?
  • shanr replied
    go to preferences then click on theme then click on the dropdown button of what you want change colour
  • shanr replied
    however lt is not greyed out so I don't know what is the cause of this
  • Chuck Shultz(fxswan) replied
    Tried all that again.... nope..  as soon as I click on segment the change it... the menu closes....
    2.83 I can use the same theme and it works fine...
    will try 2.81
    here is 2.83 using the same theme.... it works...2.81 works.... but not 2.82....
    Ok....after uninstalling blender 2.82a  and deleting the 2.82 folder in the User....app folder.... it now works.... I am wondering when I updated from 2.82 to 2.82a something in the old 2.82 folder is not updated....
    well once again it happened, this time on two  machines.... had to uninstall 2.82a... remove them from the APP folder and reinstall....came up ok... works fine on two machines
