Snake hook brush trouble : Mesh stretching out
While stretching the breathing tube in this creature. Even though I used "Subdivide Collapse" my mesh does not stretch to the full length. I am lacking the geometry half way.
  • Kent Trammell replied
    You need a smaller detail size. I'm pretty sure the devs changed the detail size function after I recorded course. I used to start at 30px --> 20px --> 10px if I remember correctly. Then I shifted to 10px --> 7px --> 5px.
    Sorry I know that's confusing.
  • Bhavesh Patel(ryzen7) replied
    No no that's not confusing. I also recognizing while following you in this tutorial that there was different detail size on the object what I was getting. As well, some how I figure out with same detail size as you had working with Snake hook brush. Only thing i changed that I pull the geometry in multiple stroke instead of single stroke as you did in the tutorial. And it worked.
    Thanks a lot Kent for quick reply! I am enjoying and learning a lot in your tutorial! You are such an amazing teacher.
    I'm so glad to hear you're enjoying the tutorial! I remember seeing you in the stream yesterday and adding quiz XP points to your account. Thanks for hanging out with us :)
