Latch Scaling Issue
When I'm trying to use Alt+S to scale the latches along normals its scaling each piece individually, they're not connected and i can't figure out why. Any help is appreciated.
TY
  • of Nodes & Noodles(gcs_dev) replied
    Hi Tristan.
    It sounds like you may have accidentally Extruded the faces (E key). Try removing double vertices by selecting the faces in question, press Alt-M, then select "By Distance".
    If this doesn't help, please post a screenshot of the issue.
  • Jonathan Lampel replied
    Hey Tristan, I'm not sure why that would happen, but try merging vertices by distance to connect them again.
  • Tristan W(derp) replied
    Removing doubles fixed it, thanks!
    That solved it!
    thanks for the quick reply
    You're welcome! I'm glad it helped.
