Fixing vertices not shrink wrapping?
Hi,
I've managed to mess up my mesh getting some vertices that are not on the shrink wrap object. They are all in the shrink vertex group and have a weight of 1.
and
How can I fix this?
Thanks
Mike
  • spikeyxxx replied
    I don't think anything needs fixing here; you are in Edit Mode and the position of the vertices is shown before they get shrinkwrapped.
    In Object Mode everything should be fine.
    If you want to see the shrinkwrapped vertices, check the 'triangle' here:
  • Mike Dodds(mikedodds) replied
    Thanks, all good now :)
