Lower metal band clasp edge problem
Hi all.
I am working on the lower band clasp. When I move the edge to make it the same size as the upper clasp it leaves a strange bevel at the top.
See image:
  • Kent Trammell replied
    It looks like you left that front edge unselected when you beveled:
  • digitalseed replied
    Would adding an edge loop just below the bevel, then deleting the top where the problem is, then adding the bevel to the new edges fix it?
    Yes I believe that should fix it. It's definitely fixable manually.
