i have a problem
hey i have got a problem. With dyntopo enabled if i try to use snake  hook it is still kind of streching the geometry and it makes the stroke thinner as i draw. Any help?
  • Kent Trammell replied
    Try enabling Subdivide Collapse as your Dyntopo refine method:
    Also if the geometry you pull out is too faceted (low poly), lower your detail pixel size.
  • alinblender replied
    well that is kind of ok  when my brush  radius is high but when the radius is small i have the same problem
    Ok thanks for the screenshot. Yeah I think you just need to lower your detail pixel size even further. The issue appears to be that there's not enough geometry to facilitate the stroke.
    Also give Brush Detail a try. That will align your dyntopo geometry resolution with your brush size: Larger brush = larger polygons, smaller brush = smaller polygons.
