Some brushes not working...
posted to: Basic Blockout
I'm encountering that some brushes don't seem to be active. I have made sure the shark is selected. The orange and yellow brushes are fine. But the mask, draw brushes sets are not working. Any advice, please?
Update: An AltM allowed to sculpt again with the draw brush. So it appeared that there was an invisible mask active. When I hit M again to activate the mask and paint a small body part,  I observed no changes (no black mask texture) but it seemed to auto apply again to the body of the shark and not the flippers.
Hope you can advise
  • spikeyxxx replied
    Hey Daniela, from your screenshot it seems that you have your Mask Brush with a strength of 1 set to subtract (the minus sign next to the strength). Try using the plus...
  • Daniela Morescalchi(pdxdaniela) replied
    Thank you for the suggestion, but it didn't work. I think I'll just start a new blend later.
    D
    ppdxdaniela There is a setting to hide the display of a mask in the viewport so that you can focus on the sculpt (or other reasons unknown to me, which are many haha).
    I wonder if you have it turned off??? It's the bottom item in the Viewport Overlays section on the header
  • thefirepriest replied
    Thanks Shawn, That fixed the issue as I was having the same problem as the OP! Cheers.
    Edit: Worked out the problem: Ctrl+M hides thes mask from view, it's Atl+M to clear the mask!
    Curse these useless human fingers!
    tthefirepriest yes that is the hotkey! Nicely done
    Thank you blanchsb that worked!
