Textures are not applying in a simple mode
Dear friends,
I am trying to apply texture to the model imported from Sketchup, but with no progress.
I'm applying easiest way, via Base color: Image texture.
You can see the Cube next to the model, with textures applied the same way and looks well.
Problematic model at left, correct cube at right.
Normals of the model seems OK:
Any ideas what can I do?
  • spikeyxxx replied
    l Hi happybirthday, it looks like the model isn't UV unwrapped.
    Select the model, go into Edit Mode, select all (A) and U > Unwrap. Then there are a few options, I'd suggest Smart UV Project for testing purpose. See what happens. (The Default Cube is already unwrapped, hence the difference.)
  • happybirthday replied
    Thank you very much! Seems it helps!
