Issues selecting bones
Hello! I was looking forward to this tutorial, but I've gotten stuck with some issues and can't seem to solve them myself.
I'm having touble selecting bones after I change the display type to B-bone, it's like they're not selectable anymore, but the outliner tab shows they are.
I can select the top and bottom parts of the bone, but I can't select the body (with neither box selection nor left-click), which means that when I'm on B-bone mode, I can't select anything at all, as I can't see the top and bottom handles.
Selecting the bones on the outliner doesn't seem to help either, since when I change from Edit to Pose mode I lose my selection.
I saw a couple of people online who came across similar problems and said it may be a bug, but I wanted to check to see if maybe I was just doing something wrong when selecting them and there was a way to fix it.
Here's my file in case that helps: https://drive.google.com/open?id=1QCpDwPXlBHAvMKlFerFVuBT4i6Jy22yo
  • spikeyxxx replied
    Hi galowglas, I checked your file, but everything is selectable. Maybe you can try clicking on an 'edge' of the B-bone, instead of 'exactly in the center'.
  • galowglas replied
    Hi, Spikey! I tried that, but since nothing was working I looked it up again and found the solution.
    Turns out it was just a matter of updating drivers.
  • spikeyxxx replied
    Glad you figured it out! And thanks for telling us what it was. I didn't realize that this could be a drivers issue. Learned something;)
  • Wayne Dixon replied
    Glad you got it sorted @galowglas
    Thanks for always helping out spikeyxxx
