Error when saving file
Hey,
I'm having problems with saving my current progress (error-message below). There seem to be some files missing for the gem. I downloaded the first file at the start of this course. Inside the gem-folder there is only a gem.blend file. But as far as I can see there also need to be other png files.   I don't know if MACHIN3Tools is just messing things up around here, but I don't think it will create those file links out of nothing. For other viewers you might want to check and update the source-file.
Also the gem is still called "Cylinder" in that version.
  • Wayne Dixon replied
    Hi ndoell
    Sorry about that.  Thanks for pointing it out.  You are indeed correct, the download version was the starting gem file and not the tidied version intended for the course.
    It has now been rectified.
    Thanks again.
    Wayne
