bevel in cycles
posted to: Baking the Normals
when i add the bevel node nothing seems to happen. materiaal is linked and i am using cycles
  • Jonathan Lampel replied
    Hmm, I can't think of a reason why. Could I see a screenshot with the result and the node setup?
  • jippi replied
    If you are using Smooth Shading you need to select Auto Smooth box in the Properties editor->Object Data->Normals and it will work.
