Simple Deform on my Lattice doesn't work as expected
Hello! I have followed this tutorial using 2.81 and everything worked fine until I tried a different type of shield.
I've made a circular one using only a quarter of a circle made with 8 verts. It has 3 modifyers NON applied: 1st Mirror on X, Y Axis; 2nd Subdivision Surface and 3rd Lattice.
The problem is with the Lattice object. I wanted to build a rounded shield using two Simple Deform modifyers. One curving de Z and the other the X.
I can't place a Second Simple Deform without messing the Shield. Locking the Y axis on the 2nd Simple Deform only makes it worse.
Could anyone help me? What am I doing wrong?
Thanks in advance! :-)
  • spikeyxxx replied
    Simple Deform Modifier can be tricky, but I think your problem is mainly that your second Deform is set to Twist in stead of Bend.
    (Tripped me up quite a few times...)
  • Monica Freire(freiredesign) replied
    Thank you soooo much spikeyxxx!
