Where is the link to the counter add-on?
Counter add-on
  • Phil Osterbauer(phoenix4690) replied
    I'm pretty sure this is it: https://leomoon.com/downloads/plugins/leomoon-textcounter/
    You could also go under Output property and under Metadata turn on frames and turn up the text size so it's clear on screen.
  • Wayne Dixon replied
    Hi Cletus, just use the meta data like phoenix4690 mentioned.
    That way you don't need to make sure the script is running (plus I don't think the text counter works in 2.8x)
    Make sure you check "Burn Into Image" and increase the font size to something readable.  (it's pretty small for large renders)
