Snapping is not working in blender 2,8
Nothing is snapping. Pls help.
  • Palo Piktor(thepainter) replied
    Hello shanr,
    More information is needed than you provided.
    What steps do you take when you try to use snap function ?
    Do you use custom keyboard shortcuts ?
    I use both versions 2.8 and 2.81 and snapping works fine.
  • shanr replied
    Is this correct or did I miss something
    I see you have toggled on the snapping in UI. In this case do not use CTRL, because it will disable the snapping while the key is pressed. When using CTRL you dont need to have snapping turned on in the UI (magnet icon).
  • spikeyxxx replied
    Hi shanr. Snapping settings look ok. (You don't need to have the roboOrb_sculpt selected, but it shouldn't matter as to how the snapping works.)
    But from this angle I cannot see that snapping is not working. Are you sure?
  • shanr replied
    Here is a another image
  • shanr replied
    Pls Help me
  • spikeyxxx replied
    In your last image there is nothing 'below' the two verts to snap to. Snapping works from your viewing angle.
