Particle not matching segments?
Any idea why this would be happening? Particle is not lining up with my segments.
Thank you!
  • spikeyxxx replied
    Hello milkteestudios,
    you hair strands do not have enough geometry in the viewport display, so they cannot follow the keys (points).
    Increase the Path Steps in the N-Panel under Tool > Options > Viewport Display:
    And to avoid future confusion: in the Properties Panel under Render > Path there is a checkbox for B-spline. If you enable that, the hair strands become more smooth, but they also will not reach the keys and even get a little shorter.
  • Kent Trammell replied
    Spikey nailed it 👌
  • milkteestudios replied
    Holy smokes, thanks a lot for the speedy replies! <3 Muchly appreciated.
