Min and Max Unavailable in Mapping Node
posted to: Materials
Hi! I'm using Blender 2.81 for this tutorial, and when I got to the point where you got rid of the texture duplicates using the Mapping Node, I found that the Min and Max options were removed in 2.8. Is there another way around this so I can achieve the same result? Thanks!
  • spikeyxxx replied
    Hi anim8ball, you could add a few nodes like this for instance:
  • Don Soarese replied
    Thx, Spikeyxxx, very helpful.
    For the anisotropy i googled an option for anisotropy use  in Eevee rendering.
    Geometry to Tangent to colormix. But not sure what the benefits are of anisotropy in this eye shader.
  • spikeyxxx replied
    @donsoarese I agree, that  anisotropy doesn't make sense on an iris, but that's the freedom you have as an artist.
    Just watched this part and he doesn't explain why he uses it either; he just likes the effect ;)
    But now I see why he used the Min and Max of the Mapping Node and the same thing can be done now in the Image Texture Node:
    This seems a bit easier than my first suggestiion, at least in cases like this. In general, when using other values for Min and Max, you'll need to use the method with the Clamp Nodes...(there are other ways, but they get more complicated...)
    Ok, merci!!, i ll try this option.
