DVC texture bakes with flat solid color...
I'm just really stuck here. After baking DVC texture I get UV map filled with solid color, instead of dirty vector colors.
What it looks like now:
https://prnt.sc/q9jj8h
Maybe someone faced a similar problem and knows what cause it and how to fix it?
Just in case, here is the.blend file:
https://drive.google.com/drive/folders/1MnKmtnhcCt8P0zlT-UzWlHz-ckTG4_kF?usp=sharing
  • spikeyxxx replied
    Hey Vasily, your Vertex Color Node is empty. Try adding the name of your vertex colors in the field like so:
    I've tested it on your file and it seems to work...
