Bsurface problem
Hi everyone,
I recently use Bsurface in Blender 2.81.  I face an issue when adding surface, it is not placed correctly(should be in where the stroke is draw). Anyone have same issue with me, and how to solve this?
  • spikeyxxx replied
    HI, I've never used Bsurfaces before, but I can confirm the incorrect behavior; the created Mesh is shifted away from the strokes you draw.
    Tested it in 2.79b and there it worked as expected, so I'd say, report it as a bug. Just press the button...
  • PT Binh(zhuk0v1811) replied
    So this seem to only happen in 2.81? In 2.80, I still use bsurface normally.
  • spikeyxxx replied
    Just tested it in 2.82 (latest build, see below) and it seems to work normally again.
    Thanks a lot. I will give a try in 2.82 build, or maybe it is time to use new poly build tool in 2.81 for retopology.
  • spikeyxxx replied
    Just be aware, that in the Daily build from Blender.org it still doesn't work!
    Wait untill tomorrow or build Blender yourself;)
