Keep getting a gap when Applying Location
So when I do the loop cut, then apply location, my middle bar has a gap in it? I have been fiddling with it for an hour now and I can't get it to un-gap ): Help?
  • spikeyxxx replied
    Hello jasonpeyj, my guess is:
    your bracket must be slightly offset from the center (of the World). Now, when you apply the location, the Origin (around which the bracket is mirrored) moves to (0, 0, 0) thus creating a gap in the middle of your bracket.
    To fix this:
    check the Clipping checkbox (under Options in you Mirror Modifier),
    tab into Edit Mode,
    select the edge loop you created in the bracket and try moving it on the X-axis until it snaps.
  • jasonpeyj replied
    Yeah, I was able to fix it by manually dragging the edge vertices myself. I just don't understand how that happened-- and as I moved on to the next steps with the brackets on top, It worked perfectly lol. Thank you for your help! It's very appreciated!
