Why is my equirectangle image not adding ?
Just the colour is being added. I am using Blender 2.8
  • Kent Trammell replied
    You mean you're loading an equirectangular image for the world but it's not lighting your scene at all?
  • shanr replied
    It is adding the colour and only a little bit of light is being added
    Is your equirectangular map a .jpg or .png? If so, those image files don't have high dynamic range which is required for realistic light contribution from an image. This is the main reason to use HDRI images (high dynamic range image) like the ones available at https://hdrihaven.com/hdris/
    Grab one of those and you will see a believable amount of light contribution to your scene.
  • shanr replied
    I hope this will be useful
  • shanr replied
    It still does the same thing
  • shanr replied
    Please answer
  • shanr replied
    Could you send another link please
  • shanr replied
    DO NOT SEND ME A LINK THAT DOES NOT WORK OTHER WISE I WILL GET  MAD
  • shanr replied
    Please do not make me mad
  • shanr replied
    I will give 12 hours to answer
    sshanr Chill please. How about you post an image of your blender scene that shows the world nodes and your rendered viewport that's not lighting up. That will help me troubleshoot this.
  • shanr replied
    Ok I will send it now!
  • shanr replied
  • shanr replied
    My HDR image is not added but it says it was added.  How could I fix this? [The red text was a mistake while uploading
  • spikeyxxx replied
    Hi shanr, it looks like you added it as an Image Texture (in the World Tab, under Surface > Color > Image Texture).
    That should be Color > Environment Texture. Like this:
  • shanr replied
    Thanks a lot
  • shanr replied
    Will you help me with this? I have added my HDR image but when to go mapping it goes to a colour and if I change the location, rotation or scale it changes colour
  • shanr replied
    Please answer
  • spikeyxxx replied
    This is a bit complicated, but there is no need to change Vector from Default to Mapping, unless you want to rotate the background image.
    It is easiest to see in the Shader Editor, set to World.
    This is with Vector set to Default:
    The orange node, which is the HDRI, has no input in it's Vector socket (left below). This means it uses the default Vector, which in this case is Generated.
    If you change that to Mapping, you are actually adding a Mapping Node like this:
    But the Mapping Node doesn't have a default Vector, so now Blender doesn't know where the image should be in 3D space...
    You should explicitly tell Blender what Vector to use; this is done by adding a Texture Coordinate Node:
    If you then connect the Generated Output from the Texture Coordinates Node to the Vector input of the Mapping Node, you have the same as in screenshot one. The difference is that now you can change the Location and Rotation of the HDRI.
    I wouldn't change any of the values much, apart from the Z-Rotation; all the others distort the HDRI.
    spikeyxxx you're a saint! Awesome explanation as usual.
