Fill option not working.
Hi guys, I can't fill some of the faces of the cylinder, no matter what I do. Some work and some don't. I've attached one of the plans that I can't fill. I select the two edges and press the F key and nothing happens. To test this I move on to the next plank and I do the exact same process and it does work. I'm not sure what I'm missing here. Also, if I switch to vertices select in edit mode and I choose 3 vertices, the filling option does work (another example attached) but if I choose the 4 vertices it doesn't.
  • Char Hunter(Char) replied
    xxandersolis change your mode to vertex and see if you have an extra vertex on one of the edges, then delete or dissolve that vertex.
  • Kent Trammell replied
    Char is right that it could be multiple verts on top of each other causing the fill operator to fail. Fill needs 3 or 4 verts to work.
    Also make sure you enable the "F2" addon which is included with Blender and a much better fill tool. I go over how to enable that at 8:05 in the video.
