Error when I tried to download the Project files.
posted to: HDRP Setup
This is the error:
Application error
An error occurred in the application and your page could not be served. If you are the application owner, check your logs for details. You can do this from the Heroku CLI with the command
heroku logs --tail
  • Char Hunter(Char) replied
    aandrepirre click on that little orange help button down below on the right.  They
    should be able to help with your problem.
  • andrepirre replied
    Thank you for your answer, but the button "Send Message", inside the "Ask" tab doesn't work (I clicked and nothing happen)
    aandrepirre for the ASK button, click on the Email link with the paper airplane. There you can report your problem  and they will get back to you through Email.
    Thank you again, could you indicate visually?
    aandrepirre  that is exactly correct what you've done above.  Just press  "send a message"  and that will email them and they will get back to you within a few hours.
    That's the problem, the button "Send a Message" doesn't work, but I don't want to take more of your time (I going to send a good old email), thank you for your help.
    aandrepirre, no problem and you're welcome.  Just one more suggestion, make sure you don't have ad-block enabled.  Sometimes they disable clicking on some things on websites.
    It's not the case, the server is return 400 - Bad Request
    POST https://beaconapi.helpscout.net/v1/3385ee56-3426-497b-8421-a461de52b28b/conversations 400
    The Json response: {"code":400,"status":"BAD_REQUEST","message":"Validation failed","correlationId":"917abab6-0832-46b4-923a-b4b088d92e35#10766583","errors":[{"field":"name","message":"must not be blank"}]}
    But all the fields are filled, probably the backend it's expect something else. : (
    aandrepirre Well we've tried everything on our end that I can think of.  Hopefully the guys will get back to you soon.
  • edboon replied
    Still unable to download these, aandrepirre were you ever able to get these?
    I gave up to be honest. : (
