Shader texture not visible, just colour
Hi, here I have 2 objects with the same metal shader. On the cube, the texture is displayed correctly, but on the building just the colour is visible. I checked the normals, flipped them, no change...
Thanks in advance
  • Markus Berg(thebergh) replied
    Try adding a Texture Coordinate and Mapping node to the texture.
  • polyrom3d replied
    Now it makes some lines... tried to change the scale, nothing changes...
    What if you connect it from object instead of generated? And if it still doesn't work, try doing a quick UV unwrap as well. Unless you already did that.
  • polyrom3d replied
    Yes that worked. Dont know why... But thanks :)
    polyrom3d I'm kind of a beginner with textures still but I wonder if you are having UV problems. Did you unwrap that building into UV's??? A blender 2.8 default cube comes with a pre-unwrapped UV map but more complex objects will most likely loss that benefit and you will have to create the uv map before you can assign a texture to it like that.
    I may be way off though.
  • polyrom3d replied
    Yes I didnt unwrap it in the first place, now after unwrap its ok :) thanks
